my seicento had a problem with the heating, the steel cable that moved by the wheel was bent and did not fit into the sheath.
I have disassembled cover (3 screws) and then I have reached another small screw that holds the cable sleeve.
thus I have the stretched cable giving heat to return to give the straight form. A lot of oil and it seems to come back in its place
I have put a cable on the other side of the wheel, it seems to be more direct and it will be harder to bend again.
picture both arrows to see site difference
