- Joined
- Oct 21, 2018
- Messages
- 19
- Points
- 55
Hello folks, newbie here. I have a 68 reg 500X with 1.4 multi jet engine. I think the handbook says 0W/30 grade engine oil. Is that correct? Many thanks for your help!
Do you mean the 1.4 Multiair petrol engine? If so, it does indeed use 0W 30 oil. More importantly, it must comply with Fiat spec. 9.55535-GS1 or you will void the warranty. Selenia Digitek P.E. is compliant. Since Selenia is part of the Petronas company, there is probably a Petronas badged oil that also complies, but I haven't found one. Perhaps someone on here knows.
The Selenia oil can be hard to find, but it's available from Shop4Parts.
Finally, check your manual to confirm what I quoted above, which came from page 206 of the manual on my 2015 UK car.
The official dealership here in Lithuania substitutes Selenia with Eneos and there seems to be no problem with that, but can't be sure about the UK situation, probably it's best to stick with Selenia to be on the safe side.
Goodcoin, does your Tigershark engine use the Multiair valve actuation system? If it doesn't, it may be less fussy on the oil.
