500 My 500C 1.2 esseesse
Some pics of my grey 500C 1.2 Pop.
Some modifications done. 6x14 ET40 (+ 5mm Spacers) Steelies of the Idea with 195/60R14 and the original chrome caps. For winter the original Steelies with 165/70R14 winter tyres and Ritmo center caps.
attachment.php
attachment.php
attachment.php
BCM replacement air filter, dual-intake air-filter housing-lid (for this I had also to change to 1.4 16V cooling system due to space...), painted red air filter housing with abarth decals, bigger throttle body from Grande Punto 1.4 8V, NGK platin spark plugs ZKR7A-10, Panda 1.3JTD mid section and 500 1.4 16V rear silencer (=50mm from catalyst to tail pipe)
attachment.php
attachment.php
attachment.php
DAB Adapter via line-in connected to original radio.
  • Like
Reactions: Gina500
Hi
The throttle body swap is interesting, have you noticed any difference in performance?
I thought that in Germany such modifications were not allowed.
Painting the wheels white to match the snow would look good.
Best wishes
Rob
I think the response became a little bit more spontanious and at high rpm you feel an improvement. But I think at least you have also to cut off the narrowing at the inlet-snorkel and install a replacement cotton air filter get the benefit.
It´s not allowed, but who will check if the diameter of your throttle-body is 40mm or 44mm...;)
On my car (2009 Euro5) it did work plug´n´play, but on a friend´s car, a 2015 Euro6 we experienced problems, even if the the part number of the 1.2 thottle stayed the same. I think this is due to necessary adaptation reset, but I don´t know how to do.
See also: http://ddlz003.kmpmag.pw/index.php?topic=683.0
First fiting of the new steelies for this summer...7x14 off-set 25 with 5mm spacers.
Couldn´t wait...now installed....big booty. :)
Yesterday it was time to say goodbye after nearly 11 years....arrivederci Gelentano.
My A595C Turismo
Now the successor has arrived! :)
"Enzo"
Now symmetric rear view.:cool:
Yesterday I installed the roof panel and the dual-interiror lamp with ambient light from the US-models. Love it!
I also changed the low-beams, high-beams and daytime running lights to LEDs. Only the fog lights remained halogen, I changed to Osram Allseason.
https://dai.ly/x7zmug2
No, I went for Auxito.
For the Low beams I took the C7 series: https://auxito.com/products/dd-c7-h7
Advantage is, you can rotate them step-less and so find the optimum light output / pattern. Due to the lens-design the cut-off stays constant. And they are so small that the rear covers of the lamp can be still used without modifications.
For the high beams I decided for the M3 series: https://auxito.com/products/dd-m3-h7 I liked them as they are all silver und so fit good into the reflektor no causing dark spots when switched off. The can´t be adjusted stepless and they are little bigger.
The light output of both is very good (far better than the standard halogens) and the price is reasonable.
A friend bought for his Abarth the Gen2 Osram LEDs and he was not so happy. One thing is, you can install them only in one position and so you can not find the optimum position for lens lamps. Another problem, they are so big, that you need to cut the rear lamp cover. And they are not permitted for the Fiat 500 / 595, too, even they are so expensive.
I ordered the C7 and will check them out. Your description and pics sound promising. Thanks for sharing the details.
For the high beams I won't bother at the moment. I can hardly use them most of the time anyway.
