Hello all! I'm hoping someone can help me with a problem I'm having with my Fiat.
It is a 2012 Fiat 500C 1.4L Multiair and it is automatic.
I'm getting intermittent operation out of my car. It will run for a while then completely die, unable to restart.
The code reads P2102 which is Throttle Actuator Control Motor Circuit Low. I have replaced the throttle body with a re manufactured one, still does the same thing. I've load tested the 1.5 year old battery, 12V the whole time. I've cleaned the grounding wire connections.
My question is, what else can I check? Fuel pump? Accelerator pedal?
Thanks for any help anyone can give.
