Not the usual resetting issue! Instrument panel on my wife's Barchetta died on her last week. Traced problem to loose contact on back of fuse panel so all fixed there BUT airbag warning light stays on. Diagnostic check comes up with 'airbag isolation switch warning lamp fault'. Replaced bulb and checked all contacts again but no joy. Isolation switch itself seems fine but warning lamp doesn't light up and error message obviously being sent to ECU.
My guess is a wiring issue but where to start looking? Also a bit scared of setting off other problems with airbag system.
Any advice or pointers would be much appreciated. Thanks.
