Technical 500l mpw 1.3d automatic warning lights
paulhelliwell
while driving home today i had both airbag lights,seatbelt light milage flashing and fuel cut off unavailable come on for no reason any help would be apreciated,
also is it safe to drive?
Seems to be the safety feature where an accident occurs the fuel supply is cut off.
The module for the fuel cut off is probably sending incorrect signals across the can bus if you have not had an accident. I would go and get it diagnosed, probably with an obd code reader or if you wish to spend a bit more get an Fiat modified elm327 and read it with multiecuscan.
Might do an proxy alignment? Not too sure..
no not in an accident and still drove home but fuel cap is locked so think i need to get it scanned thanks for the reply
been told fauly airbag ecu anybody know where its located in the 500 mpw?
fiat want £500 to put a new one in
