G GradyWhite New member Joined Jun 20, 2018 Messages 2 Points 2 Jun 20, 2018 #1 I'm getting these codes for all the cylinders. Is this an ECI issue? Where should I start to diagnose this? Thanks
Goudrons Patron member Parked in the garage Joined May 10, 2010 Messages 2,669 Points 796 Jun 21, 2018 #2 P0351 is Ignition Coil A, Primary/Secondary Circuit Malfunction. That would cause P0301 - Cylinder #1 Misfire if that coil is playing up. I believe each cylinder has it's own "pencil" coil on top of each plug, "A" is number 1 cylinder. (P0301 is misfire on number 1 cylinder). You could try clearing the codes, then swapping cylinder 1's coil over with another and see if the issue moves with that particular coil. If it does and you get a new set of codes relating to the cylinder you moved the coil too, then it's that individual coil that fubar. If it doesn't move, you've likely a wiring issue to number 1 coil. Last edited: Jun 21, 2018
Goudrons Patron member Parked in the garage Joined May 10, 2010 Messages 2,669 Points 796 Jun 21, 2018 #3 This shows you how to get at the coils. Number one is usually at the end furthest from the gearbox (left as you stand in front, though it's on the right in the vid as it's filmed from the back of the engine bay)
T typecastboy Patron member Written a guide Joined Dec 26, 2014 Messages 4,162 Points 1,126 Location Orpington, Kent UK Jun 21, 2018 #4 They are numbered 1,2,3,4 from left to right and in relief print on the coil pack itself.
