Fiat DOBLO 1.2 mpv
Fiat DOBLO 1.2 mpv
Peter1961
Hi could I put a Punto engine 1.2 into my doblo 1.2 are they the same engines cheers
What year is your Doblo?
Fiat use the same basic 1.2 engine in (almost) everything So it's likely you could find a solution to your problem under the bonnet of a different model.
If you scroll down the forum there are punto and Doblo Sections, its probably best to ask in the Doblo section and explain what problems you're having.
