I just got a Maluch in Poland. What is the lever next to the choke, with the red arrow? I believe it’s called a starter but I can’t find anything online about what it does.
Yes early versions had a lever next to the choke lever which would manually engage the starter solenoid. So to start you simply turn the ignition on an pull the lever up until it busts into life then you push it back down.
