Millmoo Patron member Joined Feb 16, 2012 Messages 58 Points 92 Location Jersey May 5, 2018 #1 Anybody know I where I can get one of these? Henk doesn't have any. Seem as rare as hen's teeth.
StevePD Patron member Joined Jun 28, 2014 Messages 409 Points 173 Location Figeac May 5, 2018 #2 Sorry no, however, if you are successful put me next on the list for any available. Good luck Steved
1 111rob0 Member Joined Sep 25, 2016 Messages 107 Points 90 May 5, 2018 #3 As rare as hens teeth Have the lugs snapped off I did a repair with some fibreglass and some centre hubs from eBay
1 111rob0 Member Joined Sep 25, 2016 Messages 107 Points 90 May 5, 2018 #5 I had some lugs that were ok so cut the hub to fit in hope that helps Still working well
OP OP Millmoo Patron member Joined Feb 16, 2012 Messages 58 Points 92 Location Jersey May 6, 2018 #6 Nice job. Only one of the lugs on mine has snapped off. Where did you find the centre hub?
OP OP Millmoo Patron member Joined Feb 16, 2012 Messages 58 Points 92 Location Jersey May 6, 2018 #8 Make that two!
1 111rob0 Member Joined Sep 25, 2016 Messages 107 Points 90 May 7, 2018 #9 On eBay centre caps just find one the same size Bit of grinding down of the original cut a action off the new cap sand all the chrome finish odd so the fibreglass will stick to it
OP OP Millmoo Patron member Joined Feb 16, 2012 Messages 58 Points 92 Location Jersey May 7, 2018 #10 That sounds straight forward enough. Thanks.
T turining Member Joined Sep 20, 2012 Messages 59 Points 61 May 12, 2018 #11 These any good/help ? Cannot give you the direct link but look at partsworld-uk
OP OP Millmoo Patron member Joined Feb 16, 2012 Messages 58 Points 92 Location Jersey May 15, 2018 #12 I had a look at the site, but don't see anything suitable. Thanks all the same!
