myte128
Hi there, strange long winded question coming up regarding 128 variants.
My 128 sedan is a mongrel of Uno Turbo, X19, Tipo, Strada and 128...
I have Strada 105TC front hub carriers (steering knuckle) on my 128 which are part number 7535184 (one side) this is so I can have the big bearings in the hub for equal length driveshafts. This hub carrier is the exact same one as used on 'modern' 128's from 1979 onward. I've also got the front arms from a Strada which have the bigger bolt hole to attach to the chassis but so far as I can see are the same otherwise.
What I want to know is...
What other differences are there (if any) that anyone knows of, to accept the 7535184 hub carrier on the 128 chassis? Does anyone know if the mounting points changed? Or if the steering rack is different (along with a change of tierods). Or wheel alignment different?
Reason for asking is...
I have found my inside wheel turns further than it needs to and tends to 'skip' a bit, plus the car is a little more understeery too which I want gone. Let me know if you know. Thanks!
