Urgent Help Required from the great and good on here
To make a loooong story short I've completed the rebuild of gearbox and engine and put everything back together, charged the battery, new fuel (tesco 99), key in and after a turn or two she fires and runs sweetly. Boy, what a moment that was HOWEVER, after running the car and completing a short steady drive to test the gears she was put to bed, cheers all round and a large glass of wine! BUT, two days later key in, try to start and I get a furious clicking noise and a very slow engine turnover that is insufficient to get her to start
One new hi capacity battery later and no change, I've checked and cleaned the Earth return cables - all ok. New battery fully charged (showing 14.4v) and again the furious clicking noise and a slow turn over????? After this the battery showed 12.6v ???. The main power cable was slightly warm (normal?) But the body of the starter motor was hot???? but not hot enough to stop touch??? The solenoid was cold??? I will add that the starter motor was a recon unit from lucas 15 months ago and has not had a lot of work since.
SO, whats the deal here - starter motor brushes worn out, bad power cable or what?????
Help, Help, Help??
Ian.
Help, Help, Help??
Ian.
