Technical Cruise control
Bosky
Hi all
New to the forums, haven't posted before so still looking around. I've got a 2014 Ducato 130 motor home (Jayco Conquest) here in Tasmania. Only done a few km so far since I got it, but am wondering if anyone can tell me how to get a display up on the dash to show what the Cruise Control is set on.
The only indication that I have seen is when I turn it off and see a brief message telling me that. Be nice to see that it is on and what speed is set etc.
There should be a green warning lamp on the RH side of the display to indicate it is on. There is no indicator for the selected speed.
Thanks for your response. That's as I thought. I'm used to vehicles with a readout on the dash of what speed you have it set for etc.
If you switch over to speed limiter you can set the max speed of that
Thanks, will have a read up to see how to set speed limiter. Drove a Merc Sprinter in NZ last year with that, and was good - put your foot down hard and nothing happens above the set limit.
