Technical 09 500 sport scuttle area full of water
West Yorkshire
i have a 2009 1.3 mulijet sport and the area under the windscreen is full of water
i assume threes supposed to be a drain area someplace anyone direct to it to try and clean it out?
edit: just noticed this is the Abarth section its its normal 500 if somebody can move it
ah never mind found it now
had to take the scuttle cover off with the three type push pins then remove the wiper blades so i could move the cover out of the way
then after blasting the are out with an air compressor i manged to dislodge enough crud for it top start draining and made me able to see the the drain points was previously covered in filthy sludgy water
the drain is in the little recessed are around the center a small rubber lined hole/ tube
gave it a good flush with warm sopay water and used a bottle brush to clean both side drains holes out the one of the other side is block by the wiper mechanism and you cant get your hand near it
