I want to change the thermostat on my 2.8Jtd.
Before I go any further with the disassembly I need some advice regarding the best approach to accessing it.
As you’ll see from the photo, the two thermostat bolts are partially obscured by what I believe is the intercooler feed pipe to the turbo charger. Is it possible to change the thermostat without removing this? Having to remove it will I suspect make a simple job much bigger.
Any advice on approach and method is greatly appreciated.
