General Fiat 500L MPW Handbrake
UKSentinel
I have an Fiat 500L MPW 2015 plate and the handbrake needs adjusting, the car has discs all the way around and I am fairly mechanically minded, just need to understand, is the adjuster underneath the car, or at the bottom of the handbrake level, which means I have to remove centre console etc?
Thank in advance
UKSentinel
The screw to adjust handbrake is located under the rear cup holder. There are no screws to take it off, just plastic locks. Than use M10 wrench .
tdq - you advice worked perfectly, I eventually got round to adjusting the handbrake and as you say, adjuster is under rear cup holder and a 10mm socket was need to adjust
UK Sentinel :)
Hello
My 2014 Fiat 500L MPW has just failed her MOT on 1 item. The handbrake needs adjusting (tightening).
I understood there was a screw under the rear cup holder that could be nipped up to tighten the handbrake. I have removed the rear cup holder but can not see a screw that could be tightened ?
Attached should be some pictures, sorry about the messy car !
From the rear of the handbrake there is a steel thread - follow this to where you should find a single nut - this is the nut that needs to be adjusted
Hello
Remove the rest of the plastic the adjuster is likely under the "framework part
Hello
Late answer but someone may need it in the future. There is a nut hidden underneath as red arrow shows on the photo you took. Need 10mm bit and ratchet to reach it.
Regards
