Technical Loose wiring behind ignition
yellowbrick
I have a Cinquecento whose lights, indicators most of the time do not work (battering warning lights on at the same time as this, not a battery or alternator, or fuses or relay problem).
Found out it is this white plastic connector housing in the picture that is the source of the problem, that when I push upwards, all works. Question is, how to go about fixing this.
Ive had a go at disconnecting this but is fairly stuck and do not want to damage anything. How easy or difficult to fix without going to a garage.
Anyone got any experience of this kind of problem?
