124spiderman
Hi all.
I'm thinking of relocating the condenser from the distributor to somewhere else closer at the coil and connecting it directly to secondary terminals at the coil (-) where the low tension wire is.
As current follows the path of least resistance I'm thinking this shouldn't be a problem and should protect the condenser from the hot engine heat.
Can anyone tell me if they have tried this?
