VeneziaBlue500x
Be warned about keyless entry. I watched someone use a similar device to the one demonstrated by ADAC.
The device works by extending the range of the transmission between the key and the car. Thus, you could be at home, a mile away from your car and the device easily re-transmits the communication sequence of the key across walls, back to the car. Essentially, the car sees such a strong signal, as if the key was right next to the car.
I did this myself and drove the car without my key. I got a warning that the key was not in the car, but I drove the car away without a problem. I was told that I could just drive until it run out of petrol, but I didn't try that obviously.
I remember watching a video of someone stealing a BMW X6 in Russia, but that required a hack in the OBD port for the immobilizer. While this trick with the range extender is much cleaner and easier to do.
So, when you are at home, keep your keys... in a Faraday cage
The ADAC video is here for your convenience:
