The Map sensor has reported faults four times on my 2014 Panda 1.2. Apparently each time because of oil contamination. I was worried about why the oil was entering the manifold and now the car is out of guarantee. So I contacted FIAT UK.
They pressed my local garage who looked at it yet again. This time they've applied a software upgrade to the ECU.
Apparently there used to be a filtration system stopping oil entering the manifold. This was removed as unnecessary. Cost saving? The trouble is that the Map sensor is too sensitive to contamination.
The new software patch apparently removes the sensitivity to contamination. We'll just have to wait to see if they got it right on the forth occasion.
It does beg the question, why not retrofit the filter again. Surely that should be a trivial job.
Jonathan
Jonathan
