RockyBalStojaaa
- Joined
- Jun 13, 2017
- Messages
- 8
- Points
- 2
Hi! How to tension auxilary belt for Fiat Coupe 20 V Turbo A/C model , but without A/C ?I would be very thankfully ,if someone helped me out whit this!!!
Please explain ac model but without ac ?Hi! How to tension auxilary belt for Fiat Coupe 20 V Turbo A/C model , but without A/C ?I would be very thankfully ,if someone helped me out whit this!!!
My air conditioner is broken , so I want to take it completely off !Please explain ac model but without ac ?
But if I take air conditioner off , than I cant tension my belt! I hope you understand , because my English isn't so good!My air conditioner is broken , so I want to take it completely off !
I don't want to leave it there because its taking a lot of space in engine bay! What does pivot means ,it islike somethings turning around?Does the ac compressor pivot to tension belt?
Or is there spring loaded tensioner?
Why not just leave ac compressor in place?
Ther isnt spring loaded tensioner , ther is tensioner you can turn upward and downward!Does the ac compressor pivot to tension belt?
I am trying to find something that would help me,for like 2 hours , and nothing![emoji1] [emoji1]Removing the AC compressor is quite an involved procedure. It's not just a case of taking everything out that's not needed. Information is on the web, sorry can't do link, but the answers are out there.
I know that I cant remove everything that's not needed, but I have seen Fiat coupe models that don't have A/C compressor!Removing the AC compressor is quite an involved procedure. It's not just a case of taking everything out that's not needed. Information is on the web, sorry can't do link, but the answers are out there.
