The car starts great when cold. Drives great but if I shut nit down it won't start until it completely cool down! Just did a valve job and timing belt change. New coil didn't help. Any ideas ?
I’m sure you’ve already gotten the info you need. But here’s my take. Your timing is off. Check your timing. If that doesn’t help. You didn’t set up your crankshaft and timing wheel correctly. That’s a bummer if that happened. But you’ll just have to suck it up and start over.
Hi Doug, I haven't checked the forum in a while as you can tell. The problem with my car not starting when warm was a bad temp. sensor keeping the start injector on and flooding the engine. Thanks for replying!
