I just got a Marea 20V that won´t start. It cranks but will not fire.
Previuos owner said it was running a few months ago, got it really cheap so wanted to give it a shot.
Haven´t been able to check spark yet. I´ve pressed emergency shutoff button.
Cleaned all electrical connectors in engine compartment. Fresh battery.
Tried cranking with starting gas, but no fire. Checked plugs and they seemed dry so problem with fuel/spark? Should fire on starting gas if spark?
Any more ideas? Will get help from wife today to check spark.
Could´nt find any fuses behind glovedepartment as stated in manual?
Only main fuses above battery and fuses next to steering wheel, all seem OK.
Should you be able to hear fuel pump when you put ignition on?
