thunnisett
- Joined
- Mar 4, 2017
- Messages
- 16
- Points
- 3
I've just purchased a 1.9 grande punto, 1.9 jtdm
Anyway it has trouble starting up from both cold & hot (So assume its not glow plugs)
No fault codes in ECU.
Runs absolutely fine once started, no misfire etc.
It just takes about 45 seconds to fire up.
It has full Fiat service History and cam belt has been changed, only about 80k miles.
what's your thoughts?
Crankshaft sensor? (Although would this cause problems whilst running?)
Test injectors - (leak off test?)
No sure where to start
