Technical Remote Key has no range?
Lewissssd
The remote entry key fob was playing up and was only working when directly next to or inside the car, changed the fob battery and no difference, any ideas?
Receiving antenna ?
- located in the left front pinlar (under the plastic fitting ?)
- connected to pins 1 & 2 of the Body computer under the glove box (for right hand driven cars)
- no fuse in the antenna circuit...
Regards, Bernie
how old is the car?
for how long do you have it?
when did it start doing this?
08 Reg, had the car about 8 months and only started doing it a few days ago, worked fine one evening and then wouldn't work in the morning and hasn't worked since then
