Technical Pedal assembly removal
loserscar
3 months of ownership, and things are starting to break on my 2011 twinair.
The linkage to the clutch pedal switch looks to have broken, and I'm not getting the gearshift arrows, or stop/start function.
I gather from another thread that I'll have to replace the clutch pedal (assembly).
I've glanced at the broken linkage, but it's cold so I didn't investigate further.
Has anyone removed/replaced the clutch/brake pedal assembly?
Is it done from inside the car, or do I need access to the other
side of the bulkhead?
Ideally, I'd like to have a good look at the part first, and see if I can fix it, and/or get a part number.
Apparently it's two hours labour for a mechanic, so it might take me a weekend.
(The other breakage is my door handle)
Cheers, Pete
1-prise master cylinder pushrods end from ballpoint on pedal
2-remove circling from left of pivot pin
3-remove pedal position sensor
4-slide pivot to right and remove pedal
Fitting is reversal of this procedure-all done from inside
