racingshed
Hi folks,
I have an intermittent power loss issue with my 1.6 multijet 105hp lounge.
Even now and again you when accelerating and then changing you get a wastegate woosh noise and then there is a dip in power as the turbo spools up again, obviously there must be some sort of loose pipe somewhere but it is strange as it only happens every now and again.
Has anyone else had or heard of this problem? Just incase anyone knew what pipe/connections to check first before i start removing everything out the engine to check all the hoses
Thank you in advance
