Technical Passenger Door/Window Problems
United Kingdom
My granny has a 2015 Panda Pop, now over a year old,
The passenger side door window has the rubber falling off of the white door, when she took it to Fiat, they simply pushed it back up and then over time it came back down.
What sort of adhesive is used in the factory to keep this on, and for good?
Also,
The window won't go down. You can hear the motor working, but it won't move down. If you lean on it, it'll go down and you can seat it into position. The window will go up normally, right to the top. It just won't come down without you needing to stick your hand on the window and give it assistance.
She should really have it down at Fiat by now, I know I would.. Though if they fob her off again, and I'd imagine she doesn't argue back, then it'd be nice to be able to fix it for her :)
