Technical 1.4 110kw tjet engine sound, is that normal?
Sorry but you have some ears problem.
First video - higher frequency sound from more rotational speed.
Second video - a little low frequency sound.
No it's not normal.
I had the same noise on my gp for some time. I replaced timing belt, tensioner, pump, aux belt and the noise gone. (3 years now still ok)
I don't really know what was the issue, everything was in pretty good shape but I THINK the noise was coming from the aux belt area.
Remove aux belt and check if the noise is still there, could be something from that area. It's the easiest/fastest test anyway.
edit:
found an old video of the noise
It does sound a little diesely... What does it sound like when you rev it up?
Sounds normal to me. Tjet sounds like a diesel when you are so close.
The other noise is the same as mine.
