Hello,
The clutch on my doblo is starting to whine when the pedal is pushed in, i'm assuming its the throwout bearing. So while im in there replacing it I thought i might aswell put a whole clutch kit in.
I'm having difficulty trying to figure out which kit i need, i've had a look on ePer and identified the original part number. Looking at sites like Euro Car Parts there are a few different options based on which make of flywheel is in the car.
But as far as i'm aware its a stock flywheel, so looking for advice on whether i need to open it up and check the manufacturer first / could i order any of them / do i order one that doesn't specify that its for a particular flywheel ?
Any help would be great!
Thank you!!
Thank you!!
