I've got a November 2014 Doblo.
I bumped the wing mirror and broke the clear lens over the trafficator bulb.
How do I disassemble the wing mirror to replace the lens.
I can't see any screws and am afraid to pull too hard on the covers in case I break something. I noticed a small button on the bottom of the mirror but it does not seem to move.
Below is some text from another posting here, but I'm not sure it applies to mine. Does it sound right?
"The painted part IS an insert. It is held on by about 8 small plastic projections which stick into the main mirror housing. To remove, insert a fine bade between insert and black outer moulding (underneath is a good place where marks won't show. Lever the two apart; then insert a screwdriver and lever until the whole thing pings off. Find a dustpan and brush to sweep up all the plastic lugs you have just broken.... (may work better in warm weather). Then paint and replace with the aid of a plastic mastic gun!"
Any help greatly appreciated.
