Hey there
I need some advice on some trouble i'm having with a Punto Evo 1.6 120hp 2011 120k km
I bought it about 1.5 month ago and i'm having some trouble
2 weeks ago I put some excellium diesel in it and the following day a faulty engine light lit up, I'm not sure it was linked to it, but read someone had that too the day after trying some premium oil... So idk
Anyway, after getting an elm and linking to my phone I had this result
Confirmed Trouble Codes
-P010F: Mass or Volume Air Flow Sensor A/B Correlation (Powertrain, Generic)
Freeze Frame
-Calculated engine load: 0.0 %
-Engine Coolant Temperature: 87 °C
-Intake Manifold Absolute Pressure: 105.0 kPa
-Engine RPM: 2490 RPM
-Vehicle Speed Sensor: 109 km/h
-Intake Air Temperature: 24 °C
-Air Flow Rate from Mass Flow Sensor: 24.25 g/s
-Fuel Rail Pressure: 51150 kPa
I was told to unplug and replug the maf sensor, I did so and cleared defaults
Thought I was good, but seems not.
Sometimes, I believe it happens after I deccelerate, the car gets into safe mod (max 3k rpm or even 2.5 depending what gear I am running), start/stop gets disabled and speed regulator too
If I stop the engine and start the car again, it goes as if nothing happened
There is no light or message coming up after it gets into safe mod, I tried to check errors with elm and found nothing
But, one test is wrong :
Mid$31 EGR monitor Test ID$80
min 38,502 max 43,827 my value 44,077
Could the safe mod come from EGR valve ?
How to know ? Could a garage tell me more than I can with elm ? I mean from reading the car ? Or will they have to guess with what I tell them, if they can't reproduce the thing ?
Could if be the MAF sensor ?
I don't know the car much, only drove about 1000km since I have it, but thinks it lacks some power, I mean before 1800-2000k rpm, I don't feel acceleration, turbo lag, or maybe DPF is dead, I don't know, but after 2k, it goes fast, and drinks alot, tho I try to keep it at 7.2l/100km
Also during that 1k km, I didn't have the dpf regeneration cycle to start, thought I read it's every 800-1000kms ?
I know the guy before me did his oil change himself, and service has been reseted when he last did, but I read there is some other thing than service to say you changed oil, and that if not reset, dpf regeneration wouldn't start, it that true ?
Just hope it's not something too pricy and that I didn't waste my money on a faulty car, I'm coming from an old 99 ibiza 1l 50hp that I couldn't see anymore :bang:
Thanks for help, if you guys have ideas...
Freeze Frame
