robjfoster
- Joined
- Apr 20, 2015
- Messages
- 12
- Points
- 3
Have been looking over previous posts and although there are some similarities, I am having additional difficulties and was wondering if anyone had any ideas.
I have a 2008 Grande Punto with just over 60,000 miles.
Generally when first starting there is a squealing noise that increases in pitch and intensity when you rev. It lasts less than 30 seconds then stops. On two ocasions this problem has been associated with a fair amount of smoke that the first time filled the inside of the car. These problems do not happen every time.
Also the car is generally noisy and is leaking a bit from the front box of the exhaust.
Today the squealing noise happened several miles down the road when the car was warm. This persisted for longer than usual and was associated with the battery dash logo. Turning the car off and on again got rid of teh dash warning.
As a bit of a background I had significant problems with the car about a year ago.
I replaced the battery, the starter motor was changed as was the alternator. Cam belt changed. Not really had any problems up until a couple of months ago.
Only real issue I have had since is the starter motor got "stuck" and woudln't work. a tap with a wrench fixed things and have not had any issues since.
The car is also going through a lot more oil than it used to. I have noticed drips of oil at the back and under the airbox. I know I have problems with the breather hose- this was split. I previously electrical taped this back together and have one on order but is yet to arrive.
Do you think all of these signs could all relate to the breather hose?
I am inclined to say the battery is ok but will check voltages at rest and revving. I would have also thought the year old alternator should be good still rather than having seized bearings. Given no real issues up until a couple of months ago suggest the cam chain tension shoudl be still good.
Any thoughts?
Thanks in advance!
Rob
Any thoughts?
Thanks in advance!
Rob
