Hello guys. I have a grande punto 1.3D 2006, with 120.000km. The third and fifth gear while driving are hard to shiftt . The transmission fluid i think has never been changed. Is this the problem or is something else. I will appreciate if you reply.
Do the faulty cables affect all the gears or just some, cuz i only have problems with the 3rd and 5th. And also its weird because it mostly happens at high RPM, if i let the RPM drop than it takes the gear normaly
Pointing towards worn synchros.. but the clutch could have an effect.
Is it the same HOT and COLD..?
