Hi, i have a 2009 Grande Punto 1.3 mjet 120hp (6 gears), i had problems since i bought it, first i had to change the turbine because the geometry was bad, i thought that would solve the problem but no, so when driving it can barely get to 5k rpm and has very little power then i turn the key a couple of times and everything is back to normal, but when the rpm drop the power is lost again and i have to turn it on and off again could someone help me (i tried changing the electromagnetic valve but nothing (i didnt buy a new one i tried a used one), the turbo exploded a couple of days ago, should i try turning the EGR off?) Thanks!:bang::worship:
