deeinlondon
My driver's side electric window works perfectly.
But my passenger side window has been playing up for several months now and totally stopped working a few days ago.
What was happening was when I started the car and pressed the down button nothing happened but when I pressed up and then down it went down.
Now it won't go up or down at all but I can hear a click as I push the button down. The battery is new, less then a year old and I charged the car fully last night using a CTEK smart charger before testing again this morning.
I opened the passenger door and opened up the connection between the door and sprayed some contact cleaner into both sides but that didn't help.
So I then took off the side of the door and managed to take off the motor and that worked fine, spun around in both directions. I then found if I put back the motor fully it didn't work, just a click, BUT if I screwed it in loosely the window then went down and then up, although at some points the window would stick going up and I'd have to manually have to give it some help going up.
So any ideas what the problem is? screwed on tightly it's not working but loosely screwed on and the motor works and window moves.
