Technical Doblo problems
John Hartup
Doblo Issues I would be most grateful for some advice on 2 matters relating to my 2007 Doblo 1.3 16v Multijet. 1. Whereas I can adjust the headlamps in the vertical plane, I cannot find the horizontal plane adjustment. Or is this fixed? Secondly, I wish to remove the plastics engine cover. I have located the (transverse) 10mm A/F screw forward of the engine but the cover won’t come away. John Hartup
and welcome:)
you'll have looked in the panda section , and found the answer to the plastic shroud question,
there is a DOBLO section - right at the bottom of FF homepage,
Charlie
