Jasper Happensprat
- Joined
- Nov 15, 2015
- Messages
- 10
- Points
- 2
I have previously removed the ignition barrel due to a locked steering wheel. That was a while back. About a month ago my 2006 JTD Ducato would not start. The Instrument lights come on and I was able to fully rotate the key through all positions.
Initially I suspected the starter motor and or solenoid. I did the usual fault tracing. To my surprise I ended back at the Ignition Key Switch. I was able to remove the plastic electrical connector that fits into the underside of the barrel. I turned the plastic wheel underneath the electrical connector to the crank position, and to my surprise the engine started. Thus it would appear that I have an electrical connector fault. However to check that the fault was not in the ignition barrel switch, I moved the gear one notch over. That action did enable me to start the engine with the key, but I promptly removed the electrical connector plugs, as the starter motor was still cranking with the engine going.
So what to do? It appears that I am unable to buy just the electrical connector. I think that my barrel mechanism is ok. But it look's like I may have to replace the whole ignition barrel switch and change the key barrel. The cost of a ignition barrel switch here in Australia is over $300. I did order a replacement barrel from Hong Kong a month ago, but alas as is not uncommon for eBay, it was never delivered. So I am thinking that I only need to jump the crank wires in the electrical connector. A suitably rated make/break push switch should suffice. Anyone else have any other bright ideas?
thanks jasper
thanks jasper
