The camera comes with two cables for video and power. Both are routed to the display unit, ground and 12V can be taken from the radio connector. I bought a single DIN radio with a motorized touch screen and installed a pushbutton switch near the radio. With the switched closed, the screen pops up and shows the camera picture; with the switch open normal radio/TV/navigation functions are available (depending on the version).
Thanks for the reply.. I haven't gotten a kit yet... Could you recommend the kit you bought if from eBay? Thanks
Hi, I have decided to buy this camera kit on eBayI have never had a "hard wired" video system so can't comment but I would say that the video quality for just reversing is fine, not brilliant but it is just an aid anyway. I suppose cost of buying and fitting will help someone decide which kit.
"The camera comes with two cables for video and power" Not all do! Mine has a video sender unit so only needs power to the display and power to the sender unit, feed for sender unit is taken from reverse switch. So until OP says what kit they have no point in trying to help them
