Goinker
Has any owner of a 500L done away with the "Spacesaver" spare wheel and replaced it with a full sized one, alloy or steel? These "Spacesavers" are my pet hate with any car as nowadays it seems most carmakers fit either these or worse still, the can of 'gunk' and a mini-compressor, about as much use as a chocolate fireguard if you're unfortunate enough to get a puncture hole larger than a pin size! My previous car (Citroen C3 Picasso) had a Spacesaver, and I replaced it with a full sized alloy, and I've been lucky enough to source another for my 500L, but the daft support fitting won't go through the centre of the alloy, and I realise that stand-off brackets under the car will have to be removed to allow the alloy to fit closer under the car floor for good road clearance, but has anyone tried this?
What many owners with a Spacesaver don't realise is that, not only are you limited to 50mph with one fitted, but the tyre only has a life of 50 miles, (very soft fast wearing rubber!) so have a run to the coast on a Sunday, get a puncture when the tyre bays are shut, and it likely won't even get you home. What a "con' by car manufacturers!
Keith.
Keith.
