- Joined
- Jun 8, 2014
- Messages
- 96
- Points
- 21
I'm still having a slightly worrying problem with cooling on this 16V.
Short history is thermostat replaced with a genuine Fiat part, coolant replaced, system bled - I think. HG job done about 18 months ago. Car usually drives with needle just under half way. However it can then drop down to quarter mark and back to half way for no obvious reason in just a few seconds. Sometimes when idling the needle's at halfway and there's not much heat from the car heater but when the engine is reved up then there's heat. I haven't had the car actually overheat yet.
Noticed some coolant the other evening which had been blown out past the filler cap. I bled the system again. No mayo on the oil cap, nothing in the coolant. Sometimes when I've been monitoring the coolant over a few days the level seems to be higher in the overflow tank than in the previous days.
Is it possible the HG is starting to fail again and pressurize the system? Could it just be the filler cap losing spring pressure? Temp sensor?
I'm out of ideas.
I'm out of ideas.
