Desmo
The car is a 75 SX. For the last couple of months it has been starting fine but with a misfire for the first few seconds. Thereafter it runs fine until the engine is properly hot. It will then snatch and stutter under light load at small throttle openings, particularly if coming off the overrun, but runs fine at higher speeds. This makes it a bit annoying to drive around town.
The plugs and plug leads are fine. I changed the Lambda sensor since this seemed the most likely culprit but the problem persists.
What next? The coolant temperature sensor? The car idles normally when warm so I'm inclined to think this might be OK.
The air temperature sensor? How do I check it? Anyone got any resistance figures at 20 degrees C ? Absolute pressure sensor?
Then there is the charcoal box thing and it's valve. What is result of the valve not functioning?
Is there anything else?
Oh yes, and the engine management light comes on intermittently. So presumably something is outside it's normal parameters.
