For some reason the links to the engines sections in Volume 3 don't work, they do on the cd but not when i copy it off, but that is the only section that it happens on that i have found. But if you browse through the files you can open the pdf's that should open from them links, its all named so they are easy to find.
Perhaps you could make this a sticky @Adrian Bravo until i figure out why it won't upload to downloads.
View attachment 4.Engine 1747 16v.pdf
View attachment 5.Engine 1998 20v.pdf
