Hi!
Sadly, I recently joined the Stilo ECU failure club as it's giving me the standard ASR & Loose Connection errors, engine cuts off and then can't be started again for some time.
I checked several threads here, along with a few other forums and I'm 99% sure ECU needs to be replaced.
The question is, can I use a newer 5NF.T9 version or it has to be an old 5NF.T1?
I read people recommending a newer version even for an older model. Will T9 work Ok with my 1.6 16V 2002?
I understand that whichever version i choose, it will have to be reprogrammed to my car and probably moved away from engine proximity to avoid such problems in the future.
P.S. Is anyone selling a used ECU or knows somebody who does?
