Technical Stilo Xenon head light
Robin1989
Hello,
I have a stilo from 2007 (New model) end have buying the factory Xenon head lights.
But i have remove my bumper end old head lights en place the factory head lights, but the xenon did noting.
I have not the connection from the picture, have someone a electric scheme to make this connection?
Sorry for my bad English.
Robin
Hi Robin, Welcome to the FF.
Are you fitting factory Xenon headlamps to a car that has normal headlamps?
Or are you fitting normal headlamps to a car that has Xenon headlamps?
Hello,
Thank you it isnt a nice forum!
I are fitting factory Xenon to a car witch normal headlamps, end some cars have the cable on the picture but i haven't not end whant create it by my self.
Robin
The extra connector goes from the automatic adjustment Electronic Control Unit (M73) in the left headlamp, to sensors (K1 and K2) on the front and rear suspension. It is an EU Regulation that vehicles fitted with Xenon HID (High Intensity Discharge) headlamps, must have an automatic method of adjusting the headlamp beams.
It is also an EU Regulation that vehicles fitted with HID headlamps must be fitted with a method of cleaning the headlamps. On the Stilo, this is done by fitting high pressure washer jets to the front bumper and a larger windscreen washer resevoir with an additional high pressure pump.
hello,
Thank you for the good information!
I think i have a challenge because i have no washer jets:(, but the connection that i not have inst that the reason that the xenon did nothing?
End the other light did it only not the xenon?
Robin
I think the wiring to the round connectors on Xenon headlamps may be different to normal headlamps. The left headlamp is the master and the right one a slave, so the 2 headlamps need an extra control connection between them. There is also an extra earth connection to Xenon headlamps for the master and slave ECUs.
Check if the metal sockets inside your headlamp wiring connectors are in the same positions as the metal pins in the Xenon headlamp connectors.
Hello,
Thank you for this answer!
My Stilo is from 2007 isnt that possible that i not have automatic wheel height adjustment?
End isnt possible to connect the heigt adjustment on the kable tot + end -?
Or say the computer than lights high of light shine to the ground?
End isnt the reason that i not have any xenon because i have no automatic height asjustment the xenon says i will not shine?:p
Ore have i a other connection that not present isnt? I have checkd de ecu cable en that are the same!:)
Robin
hello,
I can not use the headlight because the canbus:(
But now why want try to give permanently 12v who now's of this possible isnt?
Robin
Sorry for my englische
So it is not plug and play to fit these xenon headlights?
I have the connector for the height sensors and the round connector has all pins wired.
And I found a set of xenon headlights for sale for really cheap :).
Hello,
Do you mabey know where the the cables that goes to the sensor come from?
Kind regards
