Technical Motor for electric headlight adjustment sold separately
Pesa
Hi.
I got a 2006 Ducato x244 box. 2.0 JTD & Have got aproblem w/ the left headlight adjustment. Seem like the motor itself is dead. Anyone know if this is sold separately?? Or if it could be an electrical issue. The other one is OK
Appreciate any answers. Maybe someone also have a part number.
Thank You in advance
Per
Norway
For the chassis number you posted on a previous thread, the headlamp adjustment motor is available separately as Fiat part number 9949563. Fiat price for it is about £120 (GBP). If you get the Bosch part number from your old motor, you will probably be able to find a cheaper one.
Hi & Thanks
Anyone with the Bosch part number for this. Do not have access to the car at the moment.
Per Norway
Have you checked the beam adjuster potentiometer?
I had problems with my headlights not adjusting and found that the spindle which goes through the dash adjuster potentiometer had sheared causing the pot slider to remain static whilst the adjuster wheel was rotated.
Took it to bits and stuck it with superglue. Been ok since.
Have read a couple of similar problems on different forums.
Worth a quick look before spending a load of dosh!
PS just read your post again! May not be relevant as one headlamp works ok!
