Hi.
Is there any sense to change my catalisator if I have O2 sensor fault after cat continously even I changed the senor?
Basicly after I clear the errorcode I can drive random km before it popup again.
Usually it is happen when I use engine brake.
The car is also using a little bit more oil nowdays what is not solved yet. Maybe this is also matter because the sensor measure wrong signal because the increased oil amout in the exhaust system.
So the question where I need help:
1, Change the catalisator first or try to solve the oil consumption issue?
Thanks a lot.
Br. Gábor.
Thanks a lot.
Br. Gábor.
