Its a yes
However
It really is 10x easier to drop the gearbox and engine as one lump
Engine mounts x3
Coolant - Oil - Gearbox oil - Pipework - Big fusebox disconnected
Remove Driveshafts
Drop engine and box on floor gently
I took my engine out via the top
But getting engine back in was alot harder, espically when the engine slipped in its straps and was at a stupid angle for getting in....
While the engine is out
Change Cambelt - spark - waterpump and good clean
Because transmission is removed as well - i'd seriously consider sticking a new clutch in there too
It took me 3 1/2 days as a total mechanic noobisity todo it
But tbh i did have issues with 2 snapped wires causing no solenoid and no alternator charge
You need a sheltered space (garage / carport) And lots of room
An engine crane is much required too! a tilter for the crane wouldnt go a miss
If you have 1 of the 2 engine crane hooks on the exhaust manifold it saves some hassel there too!!
Ziggy
ziggy
