Hi guys, having a problem with the boot light in a bravo.
Light does not come on when the boot is opened. Have carried out various tests.
Suggests bad earth or faulty switch. Where is the boot switch? Is it a physical switch or a magnetic/level switch inside the bootlid? Which side of the boot light does it switch?
All help will be greatly appreciated.
- 1 side of light with boot open - 12V
- same side of light with boot closed - 12V
- other side of light with boot open - 0v
- other side of light with boot closed - 0v
- continuety check of negative side to known good earth - circuit open
