you would, but don't think that the super charger route is going to be any different, its just a different set of problems to solve
1st and foremost, the block was never designed to take forced induction. you have some big maths to do to sort out the compression ratios (your now dealing with decompression plates)
your going to have to find, mount, and find some way to drive the SC
then you have piping to sort out, routes ect
FMIC or a chargecooler so add
then there is the fuel side of things to sort out, larger fuel pump, injectors, FPR
your going to need a uprated clutch (hopfully you will find one) as well as better breaks
the biggest pain in the ass is getting it all maped, you have to find some one that can map that ECU, if not your looking at aftermarkit ECU's like motec ect
i suggested a 20vt, or even better for size a 16vt because the block is designed to take forced induction and you can get a complete car for under 1k, which is the bair miniumum of what the above will cost any how
even if you do get the SC working and set up, i dont think it will ever be able to be a daily driver
